RedRaider17
- VA
- 2018 GTI S
Last month, while cruising in traffic I noticed my CEL flashing. I was in 2nd gear and letting off the gas when I noticed but by the time I looked back down at the cluster it was gone. Then just last week I was pulling up to my house and again in low gear and low RPM and sure enough another flashing CEL. Throughout the entire time I have not had any issues while under load. Of course I get the occasional fish bite while at idle. However, I still decided to the VCDS tool and check the codes and see if there was something larger going on. Upon closer inspection I did notice the misfire events..which were all showing engine RPM around 800-900. I have attached a copy of the logs below. I did a realtime test with the VCDS tool and again I noticed maybe 1 or 2 misfires per cylinder (sometimes not all) during a 45-50 minute drive most of which were occurring at idle or low speeds again. Checked my coils and made sure they are all snugged up & grounding is good; the coil pack is maybe 10k miles old and same thing with my NGK plugs. Now I know these cars tend to misfire but when does it become a major concern and is there anything else I should check besides the plugs and coils? I know people tend to lean towards carbon build-up but I feel like 50k seems to early for crazy amounts of carbon already. BTW, I am APR Stage 3 with IS-38 with roughly 52k miles. The car just seems temperamental at random times; its like okay its that time of the month again better act up but then goes back to the normal and feels good for a few weeks lol.
Initial Scan:
Friday,18,February,2022,16:21:06:24262
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4608.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: License Plate:
Mileage: 83273km-51743mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F A9
VIN: Mileage: 83273km-51743miles
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CXCB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 L HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13--- CVN: EA1A8D18
Coding: 091900122424002F0000
Shop #: WSC 00066 790 00075
ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
ROD: EV_ECM20TFS0205G0906259L.rod
VCID: 372B25D1AFC868D356B-8062
VINID: 0E69C510746511A7421450811CB4594C52
3 Faults Found:
15125 - Cylinder 1
P0301 00 [096] - Misfire Detected
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 83263 km
Date: 2022.02.04
Time: 21:12:52
Engine RPM: 848.75 /min
Normed load value: 3.5 %
Vehicle speed: 9 km/h
Coolant temperature: 92 °C
Intake air temperature: 34 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 13.847 V
Unlearning counter according OBD: 40
Engine: operating status: IS
N_TOOTH: 842 /min
T_AST_SAE: 2054 s
Engine oil temperature: 100.0 °C
STATE_LS_SAE[1]: CL
FUP_H_SAE: 2710.0 kPa
FUP_EFP_MES: 11000.8 hPa
15128 - Cylinder 2
P0302 00 [096] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 81734 km
Date: 2022.01.20
Time: 18:22:16
N_TOOTH: 842 /min
T_AST_SAE: 2054 s
STATE_LS_SAE[1]: CL
15137 - Random/Multiple Cylinder Misfire Detected
P0300 00 [096] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 83263 km
Date: 2022.02.04
Time: 21:12:52
N_TOOTH: 842 /min
T_AST_SAE: 2054 s
STATE_LS_SAE[1]: CL
Readiness: 0000 0001
Initial Scan:
www.Ross-Tech.com
VIN: License Plate:
3 Faults Found:
15125 - Cylinder 1
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 83263 km
Date: 2022.02.04
Time: 21:12:52
N_TOOTH: 842 /min
T_AST_SAE: 2054 s
STATE_LS_SAE[1]: CL
15128 - Cylinder 2
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 81734 km
Date: 2022.01.20
Time: 18:22:16
N_TOOTH: 842 /min
T_AST_SAE: 2054 s
STATE_LS_SAE[1]: CL
P0300 00 [096] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 83263 km
Date: 2022.02.04
Time: 21:12:52
N_TOOTH: 842 /min
T_AST_SAE: 2054 s
STATE_LS_SAE[1]: CL
