Bikelifemar
- Stone Mountain, Georgia.
- Mk7.5
Hey Gents and Ladies. I have messages on my dash after switching out my springs which includes the ABS, tire pressure, and Airbag, does anyone know why?
Did you disconnect the battery? If so, the lights will go out after a short drive.
Have you damaged an ABS sensor?Hey Gents and Ladies. I have messages on my dash after switching out my springs which includes the ABS, tire pressure, and Airbag, does anyone know why?
Check that the wiring hasn't been damaged.No that sensor is still intact.
No- I was echoing others who had said IF the battery WAS disconnected, it would cause the codes.any codes. Check the driver side rear LCA to make sure that you did not damage the headlight level sensor.
As others have said, if you disconnect the battery, the dash will light up. Should all clear up on the first drive.
Wait so do I disconnect the battery?
