shep13
- North Pole
Just wondering what 1/4 mile should I expect to run with a manual car and a Jb1 installed on a otherwise stock Golf R. Thanks
So you think pulling the abs fuse will work? I'll try that for sure, thanks
And I'll probably go to grand bend or Sparta.
Sent from my SGH-I337M using Tapatalk
I ran a 13.1@106 with a 1.81 60ft. Ecu intervention wasn't an issue after all once I figured it out.
Car is 100% stock with jb1 on default map 1 settings. My best time was with a 200lbs passenger. Go figure.
Thats a great time, well done. I have only seen one manual stock turbo faster than that. You should put it up on vortex in the drag standings it would be the fastest hehe.
http://forums.vwvortex.com/showthread.php?7752537-New-and-Improved-MK7-R-Drag-Race-Ladder
What rpm are you launching at to get that 60 time? Seems like mine wants to drop to 1000 (3-4K launch attempt) before it goes and I don't want to burn out the clutch playing with it at higher rpms
