tigeo
- Richmond, VA area
Love it man - science. I guess the point of my questioning is: has someone taken a tuned car with XYZracerboi tuner stage 2.45 (repeating) put it on a dyno with stock plugs at stock gap and run it then closed the gap incrementally to the final magic 0.024" and recorded if this is even necessary. I would say no. I would say it's just a good easy number to use that quells a lot of drama. But that drama - is it really b/c of plug gap or is it something else? Just asking questions.75000V/in x 0.004" x ((26psi +14.7psi (atm)) /14.7) = 830 Volts
For reference, most boosted 4 cyl coil packs produce 40000V or more with the coil being capable of closer to 75000V. You don't want them running at 100% because they'll burn out fairly quickly, so target operating ranges are typically 50-75% of total capacity. Humidity and fuel quality will also have an impact.
I'm not sure I'd classify this engine as "high strung", even with a lot of boost. It's not like we have some sort of insane cylinder velocity, a high rev range, or even a high compression ratio. It's not really that sensitive.
Please ELI5!75000V/in x 0.004" x ((26psi +14.7psi (atm)) /14.7) = 830 Volts
Certainly .Please ELI5!
Don't stop, I'm almost thereCertainly .
In general we're constantly under 1 atmosphere of pressure, which is 14.7psi pressing on us from weight of air and gravity. In our atmosphere and at this pressure the amount of voltage necessary to jump from one conductor to another conductor (like two metal plates) is approximately 75,000 Volts for every inch. It sounds like a lot, but there's not much current (amperage) behind it to sustain this spark so it just has a lot of "potential" energy and you see the blue spark as a result of this energy having nowhere to go but the next conducting hop. This jump from the electrode to the grounding arm is what causes the fuel and air mixture in the cylinder to go boom.
As pressure increases it takes more voltage to generate the same spark because the density of the air and fuel increases and more of the molecules have to be excited before the spark can happen. This relationship is fairly linear (barring humidity, air quality, and fuel quality factors) so the last bit of the equation is just accounting for the ratio in pressure increase.
When you multiply by the change in gap we're talking about, the equation reduces to the voltage necessary for just that gap difference. In this case we're talking about reducing gap size, so it's 830V LESS to generate the same spark.
From here, things get more complicated with knock sensors, ecu mapping calibration, pressure tables, and a myriad of other two dimensional factors which account for how and when the charge is delivered. These calibrations are the reason you're not running full boost at partial throttle and why you're able to accelerate smoothly. With less boost the coil packs need to deliver less charge and with a leaner fuel mixture (less fuel more air), there's less "excitement" that needs to happen at the atomic level for the spark to fly. These calibrations are what the tuner can and will mess with in order to deliver spark later ("moving timing"), dump in more fuel, reduce fuel, and increase boost pressure.
Does that help?
... Stop me or I'll go on for days.... Lol
Isn't the larger the gap the stronger the spark (but as you point out it take more electric oomph to get it to there)?Certainly .
Does that help?
It's not necessarily a "stronger" spark. It just takes more energy to cross the medium when the distance is larger. A longer spark does have more time and area to make contact with the combustion material, though, which can lead to a "cleaner" burn because there's less chance left over material will exist. This is also part of the logic behind the projected plug burning cleaner.Isn't the larger the gap the stronger the spark (but as you point out it take more electric oomph to get it to there)?
Happy to share and I'm glad it's of use to you!Don't stop, I'm almost there
Really though, this is great information, and I think provides a ton of valuable insight into what's involved in making tuning decisions on a car. I dunno if the rest of y'all are just engineering geniuses or something, but there's a bunch that I don't know about modifying cars, and would love to have more information like this for my own curiosity.
At least they acknolwedge the issues are less than 1% of the plugs. Everyone posting made it sounds like a garenteed fail and exploded engine.EQT's latest spark plug post on FB: "You know what, fuck it. Use whatever you want."
I meant if they are due to be replaced. Less expensive than stock also.Or stay with stock if you're not having issues.
I honestly don't know. I just followed the recommendation since joining the forum. Someone should test.Does anyone really know if 0.024" is necessary on these OTS stage 1/2 cars? I just can't believe 0.004" is making f-all of a difference.
I have a headache.Certainly .
Does that help?
How much do they run? The last time I bought plugs from the dealer I bought 12 and they were ~38$ for 4 including tax and picked up within 20 mins of ordering online. This year all the parts have gone up and dealer is selling them for 12$/ea before tax...I meant if they are due to be replaced. Less expensive than stock also.
OK. I'll screw around with gapping when I get to my spring service.I honestly don't know. I just followed the recommendation since joining the forum. Someone should test.
