I'll let you know Monday. Finally think I've got the dampers dialed in.demi9od
A month on, are you still satisfied with the springs? Any new pics now that they may have settled?
Sent from my LG-H910 using Tapatalk
I don't think I'd run these with the stock shocks, as I imagine the stock shocks are much closer to the Koni's on soft than where I have them set now, and you would likely get a bouncy ride as well. The combination of linear springs with higher rate and relatively long travel (compared to VWR for instance) makes for large and quick rebound, which needs to be controlled.
The linear nature is confidence inspiring around corners, very predictable with little body roll. I can't say how progressive springs would differ, but just based on my observations I'd say they'd be a little better with stock shocks, as the spring rate would be lower at your normal ride height. This should lead to less of that bouncy feel with stock shocks.
Did the alignment adjust within spec with these springs? The drop is just right for sure. I would run them with stock shocks but they are DCC.
