Another reason it's hard to feel a reduction in wheel weight is the weight distribution of a wheel/tire package. The closer the weight is to the axis of rotation, the less you'll notice it as far acceleration goes.
To demonstrate this, put 5lbs weight on the ends of a 6ft broom pole. Now spin it like a baton. Now remove those and put two 7 lbs weights close on either side of your hand. Now again spin in. It's going to be far easier to spin, but heavier to hold out in front of you to spin. You've gained 4lbs, but it's far easier to spin and accelerate.
So while lower unsprung weight is beneficial, you may not always feel it accelerating, depending on where the weight was removed, hub area and spokes of wheel, and where you added weight, wider, stiffer sidewall tire. You could save weight overall on your combo, but it feel no different or even slower accelerating, especially if you added weight at the tire.
Add in the level of lateral wheel stiffness needed for your application and proper barrel width for your tires, etc... weight isn't the end all spec that we sometimes make it out to be.
Just something to think about.
