Diggs24
- de plains! de plains!
- 2015 GTI
I got a stage 3 tune but i like to stack the JB4 in order to control my boost etc a bit better and use it as a boost controllerjb4 wont show wastegate. jb4 also cant control wastegate. you need a real custom tune
Custom tuned to my specific modsWhat stage3? If not custom to your modified turbo it won’t have right wastegate pids.
Definitely have the Mahle
Will definitely look into that. But will the adaptation failing cause my boost to taper off that much?Your ecupsi boost states different. You shouldn’t need to stack a custom tune. I sold my jb4 because I got a custom tune for my ihx475. If you want 27 psi you should get atune that runs 27psi.
No cat in the exhaust. I also have tried the video tutorialDo you have a catalyser that creates backpressure and cause the boost pressure drop?
Maybe your cat is destroyed (melted, etc.) and causes this. We had this at least three times.
Often just the mechanical (APR video) setting works well without voltage adjustment with VCDS/OBD.
