Currently running into a P0234 overboost code in 4th gear only. I can reproduce it consistently. It happens very quickly after shift into fourth right around 124mph. The car will fall on it's face spike over 30psi and set off the EPC light.
Wastegate tests fine cold and hot
Wastegate passes adaptation
Swapped MAP sensors, no change
Tried 2 OEM DVs, neither held over 15psi
GFB DV+ holds the boost without issue
Seems an awful lot like boost creep. Maybe the wastegate is failing, but still passes the tests/adaptation? Maybe it's tune related. I recall a couple GTIs having a P0234 code and it turned out it was the tune. Need to do some datalogging this weekend I guess!
