IS20 issue.
Square1
Toronto
Okay you fine people on golfmk7.com I need a little help with my wife's TSI.
We put an IS20 on it along with the following bolt ons:
CTS Turbo catted downpipe
CTS Turbo intercooler
CTS turbo intake
CTS turbo BOV
CTS turbo turbo muffler delete
CTS turbo inlet elbow
APR IS20 91 octane tune
And some other small bits and pieces.
The problem is when at wide open throttle or close to it and you let off the gas it continues to surge forward for another second or two. There aren't any codes coming up but there is an issue. Any thoughts? CTS BOV? It's really loud and my wife loves it so taking it away wouldn't be good. Possible waste gate adaption? It is an IS20 waste gate on the IS20, should it have been set differently from the factory GTI settings?
Thanks for any help.
PFA
Sent from my SM-G930W8 using Tapatalk
ZuMBLe
NY
Alltrack 6MT
I have the same tune. My car did that with the stock diverter valve and the GFB I currently have. May be tune related.
Fowvaydriver
Pennsylvania
Don't say that. It just got flashed.
Did you get this resolved? I have apr87 stock turbo and if I romp it in 3rd then let off gas ⛽️ t keeps going for a second or two. Did not do this with jb4. Only after tune.
ZuMBLe
NY
Alltrack 6MT
Did you get this resolved? I have apr87 stock turbo and if I romp it in 3rd then let off gas [emoji618]️ t keeps going for a second or two. Did not do this with jb4. Only after tune.
Do you have sport mode and normal mode on your car? Maybe try sport mode? That my change the throttle mapping so it snaps closed?
I don't like driving in Sport mode throttle mapping on my car because it just feels way too on edge.
Fowvaydriver
Pennsylvania
Agree... not using sport mode. Wonder if dsg tune fixes it?
TwinDad
Fort Lee, NJ
I'm an is20 on tiptronic with jb4. Even at 25psi on e30 I don't have this issue. Stock DV if that matters
TwinDad
Fort Lee, NJ
How much boost are you pushing at say 6k?
22ish with 12-13 degrees advance. In colder air, the timing advance will be a couple of more degrees. I've seen 18+ degrees advance at 6,500. I need to get my water/meth injection hooked up so I can see that all the time with even more boost
