tmw2442
- Approved NPC storage contanier
- Mk7 R
ugh...Did you end up just using normal DSG oil? Realize this was two years ago, but thinking about doing this.
Thanks!
SO...
DSG oil whatever brand you like goes in the DSG....the dsg diff(wavetrac or any other DSG diff....) is designed to work in DSG oil....autotech is recommending motul brand DCTF(DSG) fluid
If you have a haldex VAQ diff....attached to the trans (IE golf gti with performance pack...)...it takes haldex oil and is separate from the trans please change it every 2-3 years
If you have 4motion....standard gear oil...goes in the bevel box attached to the trans....regardless of dsg or manual. Change it every 5 years
If you have a manual trans...and a wavetrac diff....autotech recommends gear 300 gear oil.
If you don't understand or this confuses you more...I recommend only having your vehicle serviced by a shop....
hopefully the this thread goes back to the grave.....end thread...please
