Working on a bunch of mechanical stuff while I figure out what I'm doing with the tune. Dropped the car off at the dealer (I know, I know, but they're the only shop nearby who aren't booked a month out and have the tools), asked to check for vacuum leaks and verify new engine adaptations were done properly (by me, but I'm just an idiot with VCDS). End up getting a DTC printout, a visual check, and an insane $180/hr bill for nothing I asked for. Sigh.
One pressing issue is the bar-tek filter adapter. No matter what I try it leaks out the top after it gets a heat cycle in it. Mechanic who swapped the engine thought it was an issue with the gasket on the filter they provide. Bar-tek insists no one else has had this issue and to just tighten it more. Personally hate it when filters are more than hand-tight, so made me cringe to try it. Didn't work. Tried a couple other filters, same thing. It's getting cold enough I'll probably just take the whole thing out, bite the bullet and do the iabed kit next spring.
One of the (I thought) easier things I had laying around was the TTRS brake retrofit. The Mk3 dust shield alone is a nice upgrade. Only slight modification is bending it back slightly where it contacts the caliper. Stripped one of the dust shield screws, don't be like me and try to use a T27 bit for a T30 screw.
Unfortunately the pads that FCP has listed for the Mk2 TTRS seem to be the thicker variant (FCP1334) which I just can't seem to fit around the 372x32mm rotors. Ordered a set of FRP3067 instead which should give a few more mm clearance. Other than that, the Hel lines from VBT fit right up. The bracket on the back of the caliper guides them well enough, and the guide on the line fits with the stock mk7 bracket on the knuckle.
Once those are all set I'll tackle adding all the other adjustable suspension links before it goes back to the race shop for the Ohlins + track alignment.
