woodardhsd
- NC
- 2020 GTI S DSG
Looking for brake advice. Picked up a low-mileage rabbit edition back in September with a soft brake pedal. Figured it just needed a flush and bleed since previous owner didn't have that done. It didn't need it by mileage, but certainly by age. Pressure flushed and bled the system. Fluid was slightly dark and did flush out a few air bubbles, but it didn't improve noticeably. Made sure to activate the ABS a few times, and tried again. This time I also finished up with a manual 2-person bleed. Got a few more bubble out, but not a noticeable improvement. Figured I was doing something wrong, so I took it to the dealer since the car is still inside the warranty window. They seemed to think the pedal is fine, so they didn't do anything else. After another month of driving and general frustration I decided to try another dealer, this time over 2 hours away (I live in the sticks.) They agreed that the pedal didn't feel amazing, but that it was close enough that they didn't feel it warranted further diagnosis. Since the 2nd dealer appointment, I performed another pressure bleed. This time I changed up the bleed order from what the manual says, and did the more traditional order of RR, LR, RF, LF. Did get a little more air out, but only from the RR caliper.
One thing to mention is that I do notice a bit of black sediment fluid each time I would bleed the rears, but it would go away after a couple of pumps. But then it would be back the next time I bled, but only for a pump or two. I was guessing an issue with a rear flex-line or caliper, but they all look fine.
I'm at a loss here. I had a 2020 GTI before this and the pedal was nice and firm. The rabbit edition should have the exact same brakes as the 2020. I'm wondering if I have a bad master cylinder or some other issue?
