Suppose I could flash back to stock and log it when I have time.
Will the IE logger still work if you flash back to stock?
I know apartment life flashing too well. I'm in the same boat as you.Hmm.. Good question, but I want to say.. yes? It's under extras in the software menu, and not related to tune. So I assume it's just pulling ODBII values.
Edit: One way to find out though. Only takes about 20-30 minutes to flash depending on how fast your wireless is. I'll just need to wait till I can get to my buddys house. Apartment life, and nowhere to plug in a battery tender in the carport.
So 66 is the max you'll see for throttle with ODBeleven logging as well? Good to know. Suppose I'll have to read up on the APR VCDS logging blog again and check what VCDS reports.Look normal to me w/r to timing etc. Almost no retard. I've logged and messed with the throttle a lot in my attempt to look at/understand the "direct throttle mod"....66% is it with OBDEleven. Other logging tools may convert that to 100%. Settle down folks....
YesSo 66 is the max you'll see for throttle with ODBeleven logging as well? Good to know. Suppose I'll have to read up on the APR VCDS logging blog again and check what VCDS reports.
Became too foggy too quickly to run any logs tonight, so I couldn't attempt to log with the kickdown switch engaged.
Interesting and weird.Look normal to me w/r to timing etc. Almost no retard. I've logged and messed with the throttle a lot in my attempt to look at/understand the "direct throttle mod"....66% is it with OBDEleven. Other logging tools may convert that to 100%. Settle down folks....last line is to the floor...
Awesome video. Thanks for clearing up that weird anomaly for us!I present the following on this matter:
You got it, it's what the KCE is here for (Karst Centre of Excellence aka my garage..ahhahaah).Awesome video. Thanks for clearing up that weird anomaly for us!
I don't know, I seem to recall I looked at all of them and they were the same - but happy to plug back in and verify.What does NORMED mean?
It's got to be a calc thing - I'm sure your'e right, another channel may show 100%, again, doesn't matter as long as you know you are floored well, you are floored!Up to you. But mind blown if the throttle only opens 66% at wot.
