Elwood
3-7-77
- Long Beach, CA
I have 17's on mine, too. Quiet and comfortable.
17”?!?!?!!?!?!!
I had seriously considering changing from 18" to 17" due to cabin noise that I thought might be directly due to the tyres and rims, but since fitting the Balancing Damper there is no point as noise issue no longer an issue.
www.vwgolfmk7problems.uk/contents/en-uk/d5_Rear_Subframe_Damper.html
Hmm...mines fitted, and TBH i'm not 100% it's made much of a difference, but then weirdly I always thought my GTI was pretty quiet anyway ? To be fair I've only driven about 8 miles since fitting it and all on pretty well tarmac'd surfaces. Maybe I need to go for a longer drive or maybe i'm not listening hard enough, but I've not experienced the "droning" from the rear that others have complained of (maybe my ears aren't what they were) . I think i'm in a minority of one.
Still glad it fitted it as any improvement in NVH is always welcome.
My original MK7 was without doubt quieter than my current face-lifted model. Whether lighter, thinner metal was used in some areas of the newer model that contributed to more cabin noise I dont know, but certainly sound insulation appeared to be far less on this newer car.I don't know why but I think this mod might be have more pronounced effects in the pre face lifted Golfs. Maybe VW skimped on sound deadening in the face lifted cars than the older ones? Just hazarding a guess.
I fitted Dynamat all over the trunk floor and over wheel arches, under rera seat and under all 4 wheel arches after removing wheel-arch protectors. I also support my spare wheel on cork pads as the actual rim will otherwise be in contact with the metal of the trunk floor.Do you have room between the spare and trunk floor? You can try a piece of rigid foam insulation between the two.
I fitted Dynamat all over the trunk floor and over wheel arches, under rear seat and under all 4 wheel arches after removing wheel-arch protectors. I also support my spare wheel on cork pads as the actual rim will otherwise be in contact with the metal of the trunk floor. Fitting dynamat or similar in the boot area is quite simple as you dont have to remove any panels and you can also fit some over the rear wheel arches to a certain extent. I also fitted the egg-box type foam sound insulation under the removable boot floor and under rear parcel shelf. The rear seat can be removed as it is just clipped into position and this way you can stick Dynamat on that area of exposed metal. What tyres do you currently have fitted?I have now had the part fitted (correctly). Took it for a drive on country roads and motorways. It is a little better on some surfaces but still way too noisy on other surfaces, a booming resonance from the rear particularly 50-70mph. Thank you for the advice to get this fitted, better than not having it and do think it has made a bit of an improvement.
What would you recommend to try and soundproof/deaden the boot? I am useless at diy so don't want to be removing panels or they'll different squeaks, rattles and noises annoying me. I bought a dodomat mlv, need to get a 2nd as doesn't quite cover the whole area. What else?
Sound deadening felt?
Foam insulation?
Any recommendations(and products/companies in uk)? Should I put anything on the underside of the rear parcel shelf or under the removable car mats?
Thank you
