Hello
Finally back on the forum after a good while away
Nearly at 60,000 miles on the car, of which over 50,000 miles have been with the complete under body coverage GolfDave has helped everyone with and the panel I created - I've had no problems with heat just to back track regarding covering the large mid section of the exhaust tunnel. To mention also that I don't have a mid silencer as its a TDI.
As my warranty is nearly up im thinking of deleting the rear back box as it is a large weight that I feel isn't needed on the car. I have a friend with the same car but as the larger output GTD. She has deleted the rear back box with no real increase in sound, which is something im not looking to increase.
Due to this I want to mention the possibility of adding the 5E0825205C panel of which covers the final cavity behind the bumper around the exhaust exit.
My thoughts for needing this is because the existing back box is very large, has a smooth underside and fills the void. This panel would cover the area and I would be able to get my exhaust guy to pass the exhaust through the area and out of the predetermined exit cut out without any heat troubles.
Thanks for any help
Connor
