Dents27
- Bolton, ON
- '19 Autobahn GTI
Why not? I'm only looking for a little boost in power, I don't plan on tracking or going mod crazy.Don't do it - there is so much better out there
Not offended at all. Your wording didn't sound like you were voicing your opinion but rather saying people who view the car as calm/refined are wrong. You said "That's not what the GTI is all about," so that's how I took it. My mistake!I'm not telling everyone anything but my view on the topic. Sorry if I offended you.
Even then, it's still a significant boost in power! We're talking 80-90 hp and tq over stock and it holds a lot of that power boost throughout the rev range. That's not small. Looks like a really great powerband to me -- very linear.Why not? I'm only looking for a little boost in power, I don't plan on tracking or going mod crazy.
It’s archaic. Take advantage of EQT’s boost weather sale and grab their stage 1 file. You can resell cobb afterwards. With uni, you’re just stuck. I had their stage 1 and 2 files.Why not? I'm only looking for a little boost in power, I don't plan on tracking or going mod crazy.
Can you explain what's archaic about it? Edit: Also, the EQT tune looks like a different power curve than the Uni 1+...It’s archaic. Take advantage of EQT’s boost weather sale and grab their stage 1 file. You can resell cobb afterwards. With uni, you’re just stuck. I had their stage 1 and 2 files.
He can't resell Cobb until he someday decides to go back to stock. Probably will need to reinstall the OEM tune to pass emissions also.It’s archaic. Take advantage of EQT’s boost weather sale and grab their stage 1 file. You can resell cobb afterwards. With uni, you’re just stuck. I had their stage 1 and 2 files.
Super fuel sensitive, you get locked into one platform, they don't update their software or create new revisions, make a noticeable amount of power less, and for me the biggest difference was the DV releasing boost on part throttle; EQT does not, so if you lay your foot off the gas for a bit, the DV stays closed and when you re-engage the pedal you're back where you started - with uni you need to build boost all over again; and honestly, COBB opens the possibility to go further; we all say we won't but then this forum happens. This is a bad place man, a very bad place.Can you explain what's archaic about it? Edit: Also, the EQT tune looks like a different power curve than the Uni 1+...
When you say fuel sensitive, you mean like it's really sensitive to octane and gas quality, causing timing pull?Super fuel sensitive, you get locked into one platform, they don't update their software or create new revisions, make a noticeable amount of power less, and for me the biggest difference was the DV releasing boost on part throttle; EQT does not, so if you lay your foot off the gas for a bit, the DV stays closed and when you re-engage the pedal you're back where you started - with uni you need to build boost all over again; and honestly, COBB opens the possibility to go further; we all say we won't but then this forum happens. This is a bad place man, a very bad place.
If you close the throttle with the EQT tune the DV will release the boost also.When you say fuel sensitive, you mean like it's really sensitive to octane and gas quality, causing timing pull?
Also, that is interesting about how the DV is used. How does EQT let off boost then?
Thisnk of it this way - you're at 80% throttle and drop down to 60%, EQT holds boost, uni releases it.When you say fuel sensitive, you mean like it's really sensitive to octane and gas quality, causing timing pull?
How does that work though? If you’re calling for less throttle, then less air is needed…. So where does it go if EQT isn’t releasing it?Thisnk of it this way - you're at 80% throttle and drop down to 60%, EQT holds boost, uni releases it.
The DV releases it just like any other tune would.How does that work though? If you’re calling for less throttle, then less air is needed…. So where does it go if EQT isn’t releasing it?
So it… releases less?The DV releases it just like any other tune would.
Haha, it goes in your combustion chamber and out your exhaust.How does that work though? If you’re calling for less throttle, then less air is needed…. So where does it go if EQT isn’t releasing it?
