CSK/Majesty Intercooler for the EA888. Purchased/installed in 2017. Does a good job cooling. If you have radiator PN 5Q0121251 EP your good to go. If you don't then you may have to modify the bottom U brackets where the radiator. I DID NOT modify it when I installed, and I stuffed it in and ran it for 5 years just fine. After taking it out I DID grind down some of the metal so it should fit properly. Couple bent fins here and there, nothing major. Hoses/clamps included. Also includes new bolts/brackets to hold the AC condenser in.
$100. Oahu residents only.
