HI CSK IC Special
DSC808
HI State
2016 GTI SE MT
CSK/Majesty Intercooler for the EA888. Purchased/installed in 2017. Does a good job cooling. If you have radiator PN 5Q0121251 EP your good to go. If you don't then you may have to modify the bottom U brackets where the radiator. I DID NOT modify it when I installed, and I stuffed it in and ran it for 5 years just fine. After taking it out I DID grind down some of the metal so it should fit properly. Couple bent fins here and there, nothing major. Hoses/clamps included. Also includes new bolts/brackets to hold the AC condenser in.
$100. Oahu residents only.
DSC808
HI State
2016 GTI SE MT
I will throw it in the ocean if no one wants it and hopefully it will wash up and find a home.
Acadia18
2019 Golf R
I think the problem is you're one of, if not the only, active forum member in Hawaii 🤣
DSC808
HI State
2016 GTI SE MT
At this point, would you consider shipping it?
Better if you just buy new or get a used one CONUS.
Shipping would be about $120 and take like a month.
30x20x6 30lbs
