2019mk75gti
- Los Angeles
- 2019 gti
Hey there guys ,
Im troubleshooting an issue right now where my 2019 gti will stutter and sometimes even die when it is at an idle for longer than 10-20 seconds and STFT and LTFT go as high as +/- 10-15% and sometimes even - 40-50% when idling so super rich.
occasionally I get codes for multiple cylinder misfire , cylinder 1 misfire and cylinder 3 misfire and flashing CEL although if u clear the codes and try to recreate for diagnostics they don’t come back.
So far I’ve only gotten the CEL 2 times however only when the car is allowed to idle for long enough to get the really rich STFT.
additionally, on the off chance that it might be the PCV valve I tried removing the oil cap when the car was running to see if there was an odd amount of vacuum and the amount of suction was so intense that it sounds like a shop vac (not just the normal amount of vaccuum)
does this mean that it’s indeed my PCV valve or are there other diagnostics that need to be done please help because I’m getting stumped.
Thanks in advance.
Thanks in advance.
