HiThis thread has the part numbers for the the bolts.
I put my helix on the bottom / wheel on top.
Just because it seems like it was designed to load off the floor.
http://www.golfmk7.com/forums/showthread.php?p=448512
Finally got around fitting sub today. The how to video made fitting so easy. Just left with two wires over, not sure if these are meant for different model. Please see image below.
Is it for UK car? It will be very difficult to get just harness, I only can suggest contact Helix as they do sell just wiring loom. What you mean by ethernet plug?Does anybody know the part number for the wiring harness and Ethernet plug for RHD models ? I'm trying to buy a 2nd hand helix sub but need to get the harness and Ethernet plug separately. Much appreciated all.
In case anyone is interested in the Helix Soundbox and doesn't want to lose their spare tire:
Mine fits perfect in my Jetta MK6 and sits on top of the compact spare tire and is completely flush with the trunk matt. Just remove the rubber feet off the Helix Soundbox enclosure (uses Hex screws). The bigger 8-inch spare tire bolt and nut part number is 3G0-803-899-A, it secures spare and Helix Soundbox. I would assume this will work the same with Golf MK6 and 7.
Many thanks3G0-803-899-A Measures about 8.5 inches. I got mine off a user on here, but he said 3G0-803-899-A comes with both the bolt and nut. On my Jetta MK6, theres still about 1.5 to 2 inches of thread left on top (as seen in my picture above) so its plenty to screw down both the spare and the Soundbox so nothing moves if you brake hard or anything like that.
Yes UK Car bakili. I dropped auditec an email asking to see if they can supply me with the cable harness. Thanks for the link. I will keep my fingers x'd that they canhttp://www.audiotec-fischer.de/lng/en/helix/products/accessory/?page=2
Sent from my SM-G950F using Tapatalk
