Guess the sensors in the picture :-)
GeorgeTDI
EU
Golf Mk6 TDI
Can anyone help me identify the two sensors indicated in the picture ? If you have part codes for them it's even better, thanks.
Carlosfandang0
UK
2024 Mk8.5 GTI
Not 100% but I think sensor 2 is the oil pressure sensor.
OldVWFan
NW Arkansas
17 GTI Sport
Don't know which is which, but oil pressure and oil temperature. Found info and #2 in oil pressure, still can't confirm for 1
anotherwhitemk7
North Texas
MK7.5 GTI
Edit: sensor 1 is the oil pressure switch and sensor 2 is the reduced oil pressure switch. Below both of those straight into the filter housing is the piston cooling nozzle control valve (the empty hole in your photo).
GeorgeTDI
EU
Golf Mk6 TDI
So you're certain both are oil pressure ? None of them measures oil temperature ?
GeorgeTDI
EU
Golf Mk6 TDI
After searching ETKA it seems there is a secondary oil temp sensor, part code 06K919525. If correct it is probably the little fucker that's been giving me bad oil sensor readings. I'm still not sure if it is the blue one in the first pic or not.
Geraruro24
California
Gti 2015
So what happened l? What sensor was giving you wrongm temperature of the oil? I just replaced the pressure sensor and above 230 it's showing me an error.
