Oil temp sensors and heater pump errors
GeorgeTDI
EU
Golf Mk6 TDI
Does anyone know if there are 2 separate sensors for oil temperature ? I have oil temp sensor errors and apparently there are 2 different readings on the tester. I replaced the one in the slump (3F907660E) but there are still errors which can't be cleared, so what about the second sensor ? Can anyone say where it is and what part number ?
GeorgeTDI
EU
Golf Mk6 TDI
The errors are:
15170 - Engine Oil Temp. Sensor (G8)
P0198 00 [039] - Signal too High
15171 - Engine Oil Temp. Sensor (G8)
P0196 00 [039] - Implausible Signal
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
I cannot find (G8) on the wiring diagrams for the MK7 Golf..or in the self study guides...& the engine temp sensor is the combined temp/level sensor in the sump....
What version of VCDS are you using?
GeorgeTDI
EU
Golf Mk6 TDI
Thanks, in the mean time I found out as well that there is only one sensor for temps, the one in the oil pan which I replaced (3F907660E). The VCDS belonged to a mechanic and was recent (19.6.2.0), but I have also been told that sometimes it reports false/inaccurate errors which have to be checked by other means/testers.
So I'll post a new thread with some logs later on :)
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
What is the sensor right below the oil filter? Could that be it? Not entirely sure... But curious.
depends on engine..but usually oil pressure...
GeorgeTDI
EU
Golf Mk6 TDI
Well I have no oil pressure warnings, so that doesn't concern me :)
Also for the other thread, the guy who did the logs is a different guy from the mechanic with the diagnostic for this sensor ;)
GeorgeTDI
EU
Golf Mk6 TDI
Another error I have, which might go away sometimes but comes back, is:
23651 - Heater Support Pump
P16C6 00 [040] - Running Dry
23652 - Heater support pump
P16C7 00 [032] - locked
Does anyone know what it means and how serious this is ?
