GTI MK7 Tail light facelift VCDS/VAGCOM coding
gtstein
Milwaukee, WI
I ordered the facelift adapter from Audiamant and they didn't include VCDS coding instructions. I tried to code it myself but the result vary although functional. The brake lights won't turn off and the inners are brake lights. They do not match the coding shown in their video. If anyone knows the coding can you please post?! Thanks.
DV52
Australia
^^^ The VCDS/OBD11 changes that you need - rely entirely on the nature of the cross-wiring loom that you used. Did you wire the new tails as shown below?
Don
DV52
Australia
inner lights working as brake lights? Did the old fitting operate the inside light as a Brake light?
Does the Parking light function work on the outer LEDs?
Is there any way thatr you can post-up your settings for the Leuchte23SL HLC10/b] set of channel? This is the Leuchte-set for the left inside light
DV52
Australia
Is there any way that you can post-up your settings for the Leuchte23SL HLC10 set of channel? This is the Leuchte-set for the left inside light
NeedSleep
2016 Golf R DSG
