Alright man thanks! I just got a high density 12V LED light strip, did you remove the small black connector thats attached to the B-pillar and just connect the LED’s cables to where the connector would have been? its not like some voltage adaptor of some sorts right?. Thanks in advance!Its in intervals but the plastic piece on top does diffuse it some.
I completely missed that thread! Thanks for pointing it out. Job done and it looks great. Much brighter than the right side which i’m considering doing as well nowI linked the guide I followed earlier in the thread. Basically what I did was pull the plug from the b pillar so you can completely remove the whole strip, cut off the old LED, and then solder the leads from the new LED to the flat white cable from the car.
I've been waffling on the same thing for the nearly two years.Much brighter than the right side which i’m considering doing as well now
