Golf R - Oily Spark Plug
DiNaMo
Canada
MK7 R
Just did my first spark plug change on a 2016 R at 38k miles. Upgrading to rutheniums and going stage 2.
I was a little concerned with the cylinder 1 plug being covered in oil though it sounds somewhat common. The coil pack wasn't covered in oil and I wrapped my socket in paper towel and tried to absorb any more but there wasn't much.
Besides that I think the rest looked reasonable?
BlackT5
Simi Valley CA
2020 GTI SE
I would do a leak down test on all cyl or bare minimum a compression test before going to the next stage.
Better safe than sorry.
Wade_GT
Los Angeles
'17 GTI S 6M
Do you have a manual trans with upgraded clutch?
If not, it could just be failed valve cover gasket ring.
DiNaMo
Canada
MK7 R
Upgraded clutch just about to be installed.
For what's it's worth the car felt smoother on the new plugs whether placebo or not but the oil is disheartening
JerseyDrew77
Virginia & NC
2016 TR GTI S 6MT
Shifted crank = shifting piston = no more cylinder wall seal = oil passing through to spark plug
I would say OP's issue is more so two things... a valve cover gasket (which really isn't a gasket) is leaking and probably his piston rings are failing.
ZuMBLe
NY
Alltrack 6MT
I would think if the crank moved enough to affect the piston seal, the bearing would be gone already? Likely all four cylinders would also have failed?
I also don't see any evidence of oil on the tip of the plug.
