yeahforbes
- NJ
- 2017 Golf R DSG
There are probably a ton of existing threads that discuss the subject line above, but I figured I'd start a new one to home in on the specific traits I'm after, listed from MOST to LEAST important, in finding some 17" wheels:
- Dent-resistant, strong. The whole reason I'm downsizing is because NJ potholes are doing a job on my 19" Pretorias which I've already straightened... which at least gave me an excuse to powdercoat!
- Popular enough that I have a decent chance at finding some used ones. I suspect this is atypical (most people want something unique) but I don't really care about that if I can get a good value instead. I might have a Golf R, but I was lucky to score it cheap before the used market went nuts! This is my dd, not a show car.
- OE fitment: accepts spherical lug bolts, 57.1mm center bore to avoid rings, reasonable offset to avoid spacers, doesn't conflict with Golf R's big OEM brakes including balancing weights.
- 17x8-8.5" so I can mount 235mm tires having about the same contact patch as my 19x8" Prets without getting into stretch/bulge. I will be mounting summer tires, as I have a totally separate snow tire setup. The snows are 18" (some old Detroits) which is how I know to skip directly to 17" this time around. I guess I could settle for 225mm on 17x7.5" but I do like a nice grippy launch now and then.
- The lighter the better, but keep in mind priority #1 which is strength. This is my dd, not a track car.
