BufLon
- Buffalo, NY
Light popped on today, got the following from VCDS. Not sure how serious the EVAP and ABS ones are, would like some views before I seek professional help (or dig in myself).
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 52 5F 75 A9
Mileage: 69461km-43161miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
75-Telematics -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CNTA) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0003
Revision: --H13---
Coding: 091900122424000F1000
Shop #: WSC 08305 993 28888
ASAM Dataset: EV_ECM20TFS0205G0906259A 001005
ROD: EV_ECM20TFS0205G0906259A.rod
VCID: 2C0103ACD683E31BDF3-8078
5 Faults Found:
17178 - Databus
U1123 00 [032] - Received Error Message
Intermittent - Not Confirmed - Tested Since Memory Clear
15072 - Engine Start Blocked by Immobilizer
P1570 00 [032] - -
15131 - Cylinder 3
P0303 00 [096] - Misfire Detected
15128 - Cylinder 2
P0302 00 [096] - Misfire Detected
15271 - EVAP System
P0456 00 [237] - Very Small Leak Detected
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 69451 km
Date: 2020.06.16
Time: 07:28:11
Engine speed: 1674.75 /min
Normed load value: 24.7 %
Vehicle speed: 16 km/h
Coolant temperature: 20 °C
Intake air temperature: 16 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 13.984 V
Unlearning counter according OBD: 40
Engine: operating status: PL
STATE_LS_SAE[1]: OL_CDN
T_AST_SAE: 16 s
MAP_MES_SAE: 70 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
FAC_TPS_1_SAE: 20.703125 %
FUP_H_SAE: 6370.0 kPa
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 K HW: 5Q0 907 379 F
Component: ESC H31 0371
Revision: 00000000 Serial number: 50364000000013
Coding: 01FA6BA13420096D0079020481CB2980D62C9000408194B400430050C009
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP_033.rod
VCID: 44D14B0C5E130B5B373-8010
1 Fault Found:
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 235
Mileage: 26907 km
Date: 2016.05.03
Time: 22:10:11
Revision: --H13---
5 Faults Found:
17178 - Databus
P1570 00 [032] - -
15131 - Cylinder 3
15128 - Cylinder 2
15271 - EVAP System
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 69451 km
Date: 2020.06.16
Time: 07:28:11
T_AST_SAE: 16 s
MAP_MES_SAE: 70 kPa
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 235
Mileage: 26907 km
Date: 2016.05.03
Time: 22:10:11
