FS: HPA MQB dogbone mount $175 shipped to lower 48
gte718h
Atlanta, GA
Price reduced to $175 shipped to lower 48. Used HPA dogbone mount for sale. Used for less than 3000 miles and replaced with a milder solution because my significant other is particularly sensitive to NVH. The kit includes everything you see here (https://www.hpamotorsports.com/products/mqb-dogbone-mount?_pos=2&_sid=f89fad03b&_ss=r) plus two additional bolts not pictured. They replace OEM stretch bolts (plus in my opinion).
The angle of the photos make the ridges look flatter than they are. The ridges are all in tact and I can assure you that you are going to have to use a 2x4 and a hammer to install this bad boy flush against subframe. Be sure to use plenty of silicone grease when installing.
Best,
John
gte718h
Atlanta, GA
The reviews say no NVH, but you’re saying you experienced too much?
NVH is highly subjective. My car definitely felt more direct with the kit installed. More so than ECS dogbone mount and bushing filler that I have now or similar solutions. NVH is worse for DSG vehicles while A/C is running and engine RPM is below 1200. Once you get going, I don't recall having any issue with NVH. It was something I could easily live with, but my girlfriend and her child said it had to go.
Thanks, J
mr wrong
Franklin TN
I have this and love it. I had some NVH when I initially installed it, but it diminished petty rapidly. And I have DSG.
gte718h
Atlanta, GA
Just the lower. Since the existing lower bushing will need to be removed first, you will have a great view of the upper bushing. You can add an upper insert at that time if you choose.
FlyByr
Ohio
2015 Sportwagen SEL
Do you have pictures or the actual parts? Is the bushing still in good form from being pressed in an out?
