2019 Golf R
- Charlotte, NC
Twist my chassis. I'll try full stiff first.Don't be a quitter, full stiff/full send.
My (hardly authoritative) research in this thread shows an FSB size increase for the Mk7.5 Golf R/GSW 4Mo/Alltrack to 25x4. That's cross-referencing the ETKA PNs with FCP's site (Mk7, Mk7.5). Has anyone confirmed the PN of a FSB removed from one of those models, especially a Mk7.5?It's driven mainly in my opinion by 1) internet bro-science and 2) PITA to install. My car handled fine with just the rear but man the front really made a massive difference in body roll reduction, much more-so than when I added the rear. I think a rear-only upgrade is a nice easy mod for many people. The front on the GSW is only 24mm stock, I believe the GTI/R/Alltrack all have a thicker front bar to start which also helps out with a rear-only upgrade on those models.
The OEM sway bar is hollow, so that graph isn't informative. There's also, like, 6 mk7 bars? Impossible to get wall thickness measurements for all the random ones out there.I've been comparing H&R, Neuspeed, APR and Whiteline bars and found this older Whiteline chart:
If my GSW has a 25mm front bar already (see previous post), the Neuspeed 25mm FSB isn't really doing much. I realize that this chart is only a rough guide since there are differences among bars (e.g., solid vs. hollow), but it's close to the numbers that APR and Neuspeed give in comparison to the 24mm R/AT/GSW FSB.
Appreciate the info in this thread, which I just read from the top. Regarding the GSW stock FSB:
I'm asking because I'm looking at upgraded bars as a matched pair, and it looks like most vendors' spring rate comparisons are to the 24mm bar.
The 24mm number I gave was measured, so that's what it is for the GSW w/4Mo. My guess is the R/AT are larger. 25 rear/27 front works great and keep in mind the fronts (H&R at least) are adjustable so two different rates to play with, I've only had mine on the stiffest setting. FSB putting in work through Oak Tree at VIR:Appreciate the info in this thread, which I just read from the top. Regarding the GSW stock FSB:
It looks like the bar I run, Hotchkis is available again and appears to be on sale.Preparing to do subframe-out upgrades on my GSW 4Mo (Mk7.5) and looking for input on sway bars. The suspension is stock, other than the "R" RSB, and a little tired after 90k+ miles. I'm upgrading to H&R Sport springs (mild drop), Bilstein B8s, solid LCA bushings (TTRS). I'm also swapping in a GTI steering rack and refreshing everything else up front.
The car is street-driven and sees family road trip duty, so NVH increases need to be minor. I like a satisfying driver's car with good turn-in and steering feedback (alas, EPAS) but will not be regularly pushing to the ragged edge. (Yes, I would buy a Miata if I didn't need to cart the kids and dog around!) I'm fine with keeping the existing sway bars if that's a good setup, but want to avoid going back in later to upgrade the FSB.
I found a closeout deal on APR's older 28.6mm bar, but I'm concerned that'll be too much (paired with their 25mm RSB). Everyone raves about the H&R bars, though at $700, it's more than I spent for the Bilstein B8s! I'll suck it up if that's the best course, just hoping to find a good upgrade path that complements the springs and dampers, hopefully for a reasonable price.
That is a good price for a FWD bar. I need an AWD version that they don't appear to make.It looks like the bar I run, Hotchkis is available again and appears to be on sale.
https://www.hotchkis.net/product/20...om-hotchkis-sport-suspension/?mk=&yr=&md=&sm=
I wonder if they found a couple of front bars while doing end of year inventory/warehouse cleaning? LolIt looks like the bar I run, Hotchkis is available again and appears to be on sale.
That might be a good option. The AWD version is stiffer, with a claimed 43% over the R stock front bar:Would this be a good “mild” FSB upgrade option?
https://neuspeed.com/products/neusp...JTPtS0sOcOFek0KIFo55iELiujhGs9O7QcXELJX9Os-PN
Ordered a SuperPro FSB 26mm with endlinks to match up with my SuperPro RSB 24mm with endlinks after reading this thread. Currently, I have the RSB set to full stiff and when pushed it's hardest, can get the rear to step out briefly on track. Looking forward to what the FSB changes will bring - thinking of running it at full soft with the rear staying at full stiff.
Background - Factory springs and DCC dampers with the Clubsport S chassis/suspension upgrades.
I think the Ohlins are a little soft out of the box, I had that setup for a while (26/24 superpro + 70/80 ohlins) and it's excellent for the mountains but due to the motion ratios on these cars you want an even stiffer divorced spring in the rear, 120-140nm imo. The rear axle does do work but you really want to keep weight pushed onto the front as much as possible out of corners.Short update: My car will now be running the updated Ohlins R/T kit with 70nm/80nm spring rates. My use is daily driving, mountain runs like Wookies and HPDE in Intermediate class. I'm running on PS4S stock R width/height.
Would you swap back in the factory swaybars or keep the 26/24mm SuperPros? If so, back them down to soft or keep them at full stiff? They're a mild bar over OEM so just wondering. Comfort is key since this is "dads car."![]()
