I love mine. That misfire feel at idle these cars have has gone away and the engine seems butter smooth in the upper RPMS now. I would not buy this expecting power gains, but rather for the safety factor that comes with having a 1pc pulley and smooth power delivery.
I have had the Fluidampr on the car since I was stage two. There may likely be some losses and gains throughout the power band, but in reality I did not buy this for a power boost... but rather the safety and piece of mind that comes with a 1pc crankshaft damper. It also just revs more smoothly too.Hi RJ, I have a question that you can answer. I read a review from Hyde in the mk6 forum and he posted a dyno graph from a retailer for a tuned Jetta (APR tuned to be exact). Above 3500RPMs it's all good with better performance too. Below that point, the fluidampr does its job (as it's stated by them and your review) but there are performance loses. In 1500RPMs there was 50lbf less torque compared to the OEM pulley. I understand that it is not the same car/engine, but that's quite a loss. Do you feel a difference in performance after installation? Or did you do it when you swapped your turbo so you can't comment which was better in this regard?
Thanks for your time, looking forward to your input and anyone's who went that route.
Does the Fluidampr give a wobbly sound (engine NVH?) when accelerate from low rpm? The sound disappeared once rpm hit above 1.5k. At standstill revving, there is no such sound or any wobble on the pulley. Initially, suspect installation issue, so de-installed and re-installed OEM pulley. No more wobbly sound. Then re-installed Fluidampr at another workshop. The wobbly sound came back! No bent or leakage seen on the Fluidampr. Any feedback is greatly appreciated..
can anyone comment on ease or difficulty of the install? what goes into this? doing a fluid damper wasn't too hard on my cobalt but not sure what more goes into these on our space-age cars haha.
