El_bigote_AJ
- Las Vegas
- 2019 GTI bunny
You are asking him how he would know his butt dyno (user feedback) would know if it likes the TS better? Lolhow would you know it likes the Turbosmart better?
https://www.darksidedevelopments.co...-pressure-sensor-small-probe-03k-906-051.htmlWhat’s the PN for the 4bar you are using?
right, I was looking for actual results, not just "it likes it better"You are asking him how he would know his butt dyno (user feedback) would know if it likes the TS better? Lol
Listen to this man, he dynoed at 650hp...Just use the stock DV guys. Stop making things hard on yourself.
So your clarification is that you would like actual results of HIS butt dyno (user feedback). Haharight, I was looking for actual results, not just "it likes it better"
I mean, I thought he was logging too or something idn man, I heard its now at 700HP with the oem DVSo your clarification is that you would like actual results of HIS butt dyno (user feedback). Haha
As I’m experiencing this right now while getting tuned with Cobb - if they file is not written with the right scaling it shows on the AP gauges For the boost and also the car not only throws a code but it goes into limp mode and won’t boost at all....
......I've got a 2015 stock DV; is there an updated OEM DV or are they all they same from 2014 to present?
Yeah, I already got one just wanted to make sure it’s the same as others.I got mine here about a month ago. Cheapest place by far, but they are currently out of stock. Not sure how quickly you need it? Maybe give them a call and see when they will get some more back in stock.
https://www.europaparts.com/map-sensor-03k906051.html
Sorry to clarify are you saying the tune you received didn't account for upgraded MAP/PUT sensors so it went into limp mode?
I’m sure it’s had revisions. Mine holds 28-29psi to redline just fine. OEM 2015Yeah like Diggs24 said, the Bosch 4 bar is 03K 906 051. The Bosch part number is 0 281 006 059. I think I got mine from summit, can't remember anymore, pretty sure I got it stateside though.
Haven't done any new logs with the stock DV yet, but if it doesn't throw a CEL at 6k+ rpms I'll call it a win. Has the stock DV changed since 2015? Do all the MK7s use the same one?
You could just say 28lbs.mine holds 480whp of boost stock 2016 DV
