Long time lurker. So 2017 Golf AT with 40k with APR Stage 1 (only last 4-5k). Plugs replaced/gapped right before the tune, along with filters. Oil every 5k. Proper octane fuel, although it did get a good bit of injector cleaner on this tank, probably more than it called for but nothing crazy.
Last night, I hammered it coming out of a turn and it was a little wet out so I wasn't getting much traction, revs shooting up to 6-7k and back down and back up without much acceleration. When the revs shot up the last time, the engine made a weird bogging noise and EPC light came on. Car started vibrating like crazy (maybe a cylinder not firing??) and I slowed down to a stop. I turned off and on immediately and everything was okay. Lots of hard throttle today with no issue.
No scan tool to read any codes. No check engine light or anything, just the EPC which reset after I restarted the car. Any ideas??
Also, is it bad to stay on the throttle when I don't have traction? Like when the revs are shooting up to almost red line and back down a few times quickly from loss of traction. And I swear I've seen the needle go all the way to 8k at some point a while back from doing this. Is that just the gauge not reading properly or is the engine actually revving way too high?
Thanks for your input!
