Hi all,
I was hoping for some advice.
My Golf MK7 GTD on startup shakes significantly and even on idle there is a continuous shake.
I've added a video of this: https://youtube.com/shorts/NHnIVqEMme0?feature=share
Is this normal?
On startup, the car can sometimes take a while to turn over and I often have to leave the key in to warm the glow plugs for a good 5 / 10 seconds and then even then it feels a little hesitant.
Separate point is that at low speeds in the cabin it feels normal, but at high speeds 80+ it feels as if the whole car is vibrating coming from the engine itself.
The following fault codes came up on my OBD reader and I had initially thought they were causing me poor fuel economy:
16388: Fuel Volume Regulatory Control, Circuit High
16401: Crankshaft / Camshaft Position Correlation Sensor B Bank-1
any help would be appreciated!
Is this normal?
