Endlink Recomnendation. SuperPro EL shit the bed.
anotero
Hither and thither
Mk7 GTI
So the indestructible SuperPro rear endlinks shit the bed. I've been hearing clunking coming from the rear for a while, specifically during certain braking instances.
I got under the car today and discovered that my left link came apart. It's possible the shop that did the installation three+ years ago just shoved the links into the control arms too hard -- it's a tight fit, and over time they just came undone.
What are the rear endlink recommendations? Moog? ECS? Links would be much appreciated.
If it helps, I run an ST 25mm RSB.
Desslok
PA
2019 Rabbit
If you do your own oil changes, yep, get a grease gun and a tube of synthetic grease. Otherwise, make sure it gets done by whomever services your car.
I am probably overdue to re-grease mine. Been over a year since install. No issues, though.
Don't run them without grease.
anotero
Hither and thither
Mk7 GTI
Roger. Thanks.
Dog Dad Wagon
Go Birds
16 Touareg TDI
Also, OEM Endlinks are perfectly sufficient, and make no noise!
I have been through it all with endlinks and have settled on reverting to stock, after reading that Jim has been on stocks for like 80K miles w/ no noise or issues
anotero
Hither and thither
Mk7 GTI
The studs on the stocks cracked when i tried to remove tge nuts. So there's that. :)
aaronc7
17 S3
My superpro end links failed like that before I installed them brand new so....... lol
Yeah, I will go going Moog if I ever replace the stock ones.
Even more amazingly, ECS actually refunded me for the bad parts
nok513
Orange County, NY
2020 VW GTI S
If you go with Moogs, be prepared to have skinny wrenches if you don't have them already. Unless you're taking out the RSB to install them and torque it down before re-installing. They went loose on me a few times because I was too lazy to remove the RSB when installing them.
anotero
Hither and thither
Mk7 GTI
Got 'em skinnies. :D
Supermoto
San Diego
2019 Autobahn DSG
As others have said, I only hear great things about Moog. Hit them with some enamel paint if you wanna prevent surface rusting.
