I’ve been running coilovers for about a year and a half now and was getting some clunking from the front end. Had some issues with a spring collapsing on Solowerks, ended up switching to an H&R setup. Still got clunking. Put in adjustable end links which fixed the issue. BUT, I can’t get them aligned correctly and they were (or currently) rubbing the inner fender pretty significantly. I haven’t noticed any clunks or any noise, but it’s pretty obvious where it rubbed, to the point of slightly damaging the head of the end link. I’m at a loss for how to adjust the coilover/end link to make this not rub. To check if it’s currently rubbing, I was gonna spray the bare area with some fresh paint to see if it rubs off again. I’ve attached some photos (car is jacked up so suspension is sagging). When I initially set up the end links, I had to rotate the coil body a bit so it didn’t hit the big flange thing where it attaches to the end link because it was hitting. Thanks in advance.
