I made the changes under the 55 - Headlight Regulation. I'll see if I can notice a difference.
Hey guys I could use a little help. I just purchased a new to me Golf R from carmax and noticed the AFS wasn't doing anything. It seems like the previous owner disabled it. I'd like it turned on, along with the euro settings.
I have an OBD11, but I can't get it to accept any changes to the long coding, or any basic setting calibration-I just get an error that says minimum conditions not met.
Does anyone know what could be causing that error?
Also here's screenshots of my module 55 settings, if someone else with a 16' golf R or similar could if there's any settings beyond the ones listed in this thread that have been messed with, that'd be great.
https://imgur.com/a/QLsxR
As far as I can tell he tried to turn on Europe settings, but didn't know to do the reset adaptation thing and to clear the warning light he turned off all adaptive lighting settings with vag com to get rid of it. It looks like even the non Euro settings are set to off in my car.I can't see why someone would disable it in OBD11 when you can just turn it off.. so maybe a silly question but is it enabled in the car menu and/or are you in race mode or custom mode with it turned on? Sometimes it's hard to notice if you're not looking for it and it's only above a certain speed (i think 20ish km/h?).
And I am in race mode with it turned on.
There are two different cornering effects right? The beams actually moving and a separate cornering light that comes on when you turn with high beams? I have neither so far as I can tell.
Sent from my LG-US996 using Tapatalk
Yeah those two are both definitely disabled. And yep, I entered in the 20103 code and it took it, still threw the error. After a little googling it seems like it could be an OBD11 issue, so I've ordered a VCDS cable. Hopefully that'll be what I need to fix it, otherwise I may have to take it to my mechanic.
But if anyone with a 2016 R could share screenshots of their module 55 settings I'd greatly appreciate it.
