I do have the VAS connector if anyone needs it when I'm done with jack. I paid $70 on eBay for it.
Yes please.
Does this mean that if I get Component Protection removed at the dealership (legitimately) Bluetooth, Performance Monitor, and the SD Card Slot will not function?
If that's the case, I shall be Skyping to Poland...
I also just did the full MIB1 to MIB2 conversion (non-nav) in my 2015 GTI. All in all for parts alone cost me $160. I bought them from a salvaged 2017 GTI S (S model is same as my car) on eBay. Got a killer deal. That's screen/glovebox unit/USB wiring. My friend works for VW so we went there and removed CP. Couldn't find FeCs to transfer and we were strapped for time. I'm going to have Jack program the FeCs and Carplay. so total it's a +/- $500 package for me which is stellar.
The stock FeCs on my MIB1 are:
00030000 AMI (USB Enable)
00050000 Bluetooth
00070100 SDS
That's all.
Currently with everything wired up and CP removed I get power to my USB (charges my Pixel 2 FAST) and AUX works for audio. So I do know this should hopefully work once FeCs are taken care of. Under the sources I do not see Bluetooth or USB currently. Aux/SD Card/Disc work fine. I haven't looked at XM yet. Phone button/Voice Button/Carplay obviously does not function yet either.
Stuntnuts: I would absolutely swap 5G0-035-222-E into your car. I got it for like $60 on ali. Took a week and a half to arrive. There is also a yellow connector that plugs in the back of the MIB2 (I thought it might be for the AUX) as well as the green one that goes into the lock. Perhaps it NEEDS this configuration for USB to work properly with the MIB2 unit.
Though it is also concerning you do not have an FeC for USB so maybe even with a new USB/AUX it just isn't going to work.
Oh and greetings to another fellow Mainer
I wouldn't get too excited just yet. First see if you can get carplay activated. I tried and no luck. Spent hours with the tech. Entered the code and everything. Ended up getting a unit from APG.
A few questions:
1) Is the MIB 2 a 6-inch screen or 8-inch screen?
2) Is the USB port 1.0 amp or 2.4 amp or what kind of amperage?
3) Does this have Mirror Link? Does it directly mirror your Android phone's screen? (Basically could I do that MIB II option or should I just get the navigation?)
4) Why is the Fender MIB 1 amp different from the MIB 2 amp? Is it the connectors or what's special about this?
Weird, I have the same part number and software version and my Performance Monitor works.
Did you have to do some coding changes to activate it? If so, can you post them? I have the same part # and software version in my 2017 GSE and would like to enable the performance monitor.
I'm pretty certain Performance Monitor was tied to an FeC and only certain cars came with them. Basically luck of the draw. People have tried to enable with VCDS with no success.
Feature enable code. Talks about them in this thread and the OP. Basically all the features within the MIB are VIN specific and the FeC codes enable them.Okay, but what's an FeC? Is that like a pay for play feature activation?
