Discover Pro Euro Radio 8" - Retrofit into NA MK7 GTI
fluidd
Toronto
Hi All,
I am wondering if anyone has been able to try this out.
I am thinking of Retrofitting the European 8" Discover Pro Radio Unit, into my North American MK7 GTI. Up here in North America, we weren't fortunate enough to get the beautiful big screen that the European version MK7 GTI gets.
Please find attached source link: http://www.kufatec.com/shop/en/volkswagen/golf/golf-7-5q/radio-composition-colour-vw-golf-7
If anyone has tried it out there, can you please let me know the issues (if any) that you ran into? If someone can post a tutorial (if needed) that would be great also. (I am hoping its just simple plug and play)
Thanks guys!
georgy
Toronto
Hi All,
Please find attached source link: http://www.kufatec.com/shop/en/Volk...e-Set-Front-Rear-Parking-Assist-VW-Golf-7-VII
Thanks guys!
Did you even take the time to read the link that you provided?
mcmaddy
Sunderland UK
It's not possible to retro fit due to the component protection problem. Physical fitting of the hardware is a simple job but VW won't unlock the component protection. Basically if it's not fitted as standard then you've had it.
fluidd
Toronto
Good to know! Thanks for letting me know. I will wait until someone figures out a way to get it done on here. In the mean while, I will make due with my 5.8" :(
stedes1
Hey there. Component protection exists only for VW to check whether something is stolen or not. When a new electronic part is fitted, the car connects and "talks" to a db in Germany and checks if the part is in the "stolen list". If not then you're good to go.
The problem with the discover pro is twofold. One, don't forget that it's not just the screen which is different but also the unit in the glovebox and some other hardware as well. Second, there is probably a reason you didn't get it in the US (just as we can't get it in Australia either). I believe the reason for Australia might be that maps for the Discover Pro satnav are not available for this country. It could be similar to the US.
A bunch of people in Australia have successfully managed to retrofit this to a base Golf that came with the Composition system but they are stuck with the satnav (search on vwwatercooled forums and you will find the thread).
Lastly don't forget....buying all that equipment new will be very expensive!
Wolksvagen
Banned
New Zealand
FYI, the discover pro is available in New Zealand, seen them on the showroom, I know of someone who owns one and I have a mk7 due very soon with a nav pro fitted.
We (NZ) use the same region maps as Australia, may not be a mapping issue?!?
mrlapou
UK
Got the Dis Pro in my used GTi . I personally hate it. Navigation and maps are very poor. Always use the TomTom on my phone.
Oh yes, by default screen may freeze or default to VW in Germany !!! what's that all about ????
I live in the UK
jimma_uk
Southampton
I live in the UK
Occasionally mine will display the map of Ingolstadt when first switched on until it picks up the GPS signal. This normally happens when my car has been parked under cover at home for some time. It does pick up the GPS very quickly though, so normally only 2-3 seconds of Germany.
IMO the Discover Pro is vastly overpriced. However, it does finish the interior of the cabin off very nicely and every time I have used the nav, it has been very good. I like the completeness of it, hate wires draping over the car.
mcmaddy
Sunderland UK
If the unit isn't working properly then take it back to the dealer to fix. Don't assume the nav pro is poor just because yours doesn't work. The maps are good, the routes are good and it works as it should. I haven't had any issues at all with mine.
Print Screen
London
Does anyone know a company in the UK who would do the retrofit?
The usual ones mentioned on here don't seem to do it, for a MK7 anyway.
Sent from my Nexus 5 using Tapatalk
