Acadia18
- The Greater Boston Metropolitan Area
- 2019 Golf R
Did you scan the car?
Can't, nothing will connect. Says to turn on the ignition, even if the ignition is on.
Looks like your bro has gotta pee.
Have you tried a multimeter/swapping batteries yet? I only ask because I wouldn't take what the car's screen said was voltage as hard fact.
Just cold as fuck out here man...Looks like your bro has gotta pee.
Thats part of the future plan for it.. but if it keeps acting like an ungrateful shit it's going to become someone elses problem...Is it getting a Vortex while the battery is out? Halfway there or so i'm told....
Weird... all the "other" systems will fail with low battery voltage. Somewhere from 9-10V you'll start getting failures. But since you put your battery in that should be ruled out. An immo problem shouldn't generate all those errors, but should give you an Immobilizer Active message (or something like that).
I wonder if the alternator took a crap. I would think the car might start then shut right off due to the battery voltage drop. Push-button start?
love the avatar sync fliptrocity & arcadia lol
best of luck... only thing i can relate to is a similar situation where my ECU shorted out (poor ground to block), needed a new ECU. Different platform though (GM)
Gotcha... how do you turn ignition on without starting the car? This is just a curiosity question about how KESSY works, not really about the issue at hand.Yep, an Autobahn with kessy. Alternator popped into our heads, but it has the same error and connection issues even if you just turn on the ignition without turning over the car to start it. At that point, the alternator shouldn't even matter, correct?
My current thought is something in the ignition system somehow, since even though it "starts", it's not recognizing that the ignition is on.
