Nitsrik1976
- Essex, UK
Got a pro Nav Gen 2, AM and FM work fine all the time. DAB comes up with an 'antenna' logo with a line through it (no signal indication) when the car has been left for a while and none of the stations pick up a signal under DAB!
It's as if the D.A.B (during the boot process) forgets something.....if you do a soft reset by holding the pwr button down for appox 15 seconds it usually sorts the problem or if you do a soft reset when it is working properly it will create the problem so in my opinion it's a DAB 'bootloader' issue.
I've done several soft-resets and factory reset via VCDS as well...even unplugged the battery....no fault codes in relation to the Infotainment (5F) ....help please! I'm lost! Car is 3 months old.
Unit is on: 0343 software
part number: 3G0 035 020 B
