I took out the bolt on the lower wishbone that goes through the bushing closest to the front of the car and greased it up really well with some multipurpose grease and also got a small paint brush to grease down inside the bore of the bushing and tried to get some in around the sides of the bush and still have the squeaking noise, my problem sounds the exact same as yours sherbet! Slight turning of the front wheels to the right aggravates the noise however turning to the left doesn’t seem to cause it, I used the hollow pipe handle of a brush and put my ear to the end of it to try and isolate the sound and it seems to be quite loud coming from the top mount area but it’s hard to tell exactly, I might try and remove the coil spring and inspect and try abit of grease on the coil spring mating surfaces and see if that helps, il post results here when I get around to it, hoping it’s not a top strut mount as it’s only coming up on 65k miles now but seeing as your having the same problem as me with far lower miles it gives me hope [emoji16]
