KevinC
- '19 Golf R, '21 M2c
Mk7 version of EA888 supposedly much better than previous versions at resisting carbon build-up. Just give her a good Italian tuneup every few thousand miles, and drive happy.
FWIW - I did a DIY carbon cleaning on our R56 (Mini Cooper S), using walnut shells, a cheap hopper type sand blaster bin, and a slightly modified shop-vac nozzle to catch most of the shells. If you're handy, and already have a compressor and shop-vac, it can be done pretty cheap. It got the worst of the buildup, but there were a few areas that needed work with a pick.
The car ran better afterward, but not hugely better. Mostly, it was worth it for piece of mind.
I had a Stage 1 MKV before this car so I know how bad the problem was. I put up with it for about 40,000 miles. The only thing that helped was updating to the newer version higher-rated fuel regulator but that only helped hard starting.
Refresh my memory - do MK6's have the problem?
Italian tuneups don't do shit. And, if they ~were~ to do "Shit," one would have to do an italian tuneup every couple hundred miles to noticeably reduce/minimize buildup.
I beg to differ. They may not do much in all cars but they have definitely helped in past cars that I have had, especially with higher mileage. This was actually written in a VW patent.
"An additional approach for reducing the formation of carbon deposits on the intake valves is to increase the intake valve temperature, at least temporarily, since, surprisingly, it was found that any carbon deposits possibly present are removed at temperatures above 380° C. To this end, the intake valve unit, which comprises, among other components, the intake valves and the valve stem guide, is designed with means that hinder heat dissipation in such a way that increased surface temperatures of more than 380° C. develop at least in the area of the neck of the intake valves in at least one predetermined region of the load characteristic diagram of the internal combustion engine. The intake valve temperature is above 380° C. in the shaded region 112 b of the characteristic diagram. At these temperatures, carbon deposits on the intake valves are removed. This region of the characteristic diagram occurs, for example, at speeds over 3,000 rpm, and in that speed range extends essentially to full load. Even if the internal combustion engine is not operated most of the time in the region during normal driving operation of a motor vehicle, nevertheless, carbon deposits that could adversely affect the operation of the internal combustion engine cannot build up, since their removal occurs very quickly. For example, operation of the internal combustion engine in this region for a period of, for example, 20 min., is sufficient to remove even a thick layer of carbon deposits. In other words, a routine expressway trip cleans the intake valves sufficiently. "
https://www.google.com/patents/US6866031?printsec=description&dq=valve+coating+carbon+VW
Original Assignee Volkswagen, Ag
MW and Mazda have used an oil separation system on their turbocharged engines (like a catch can that separates out the oil and air and puts them back into the system in their respective places).
