Comprehensive list or torque to yield hardware required for clutch change.
-DK-
Bay Area
2017 GTI SE
Well, that time has arrived and I need to install a new clutch. I’m wondering if anyone might have a list compiled of the TTY hardware necessary for the installation? I could watch some YouTube videos and take notes if not. Thanks
krs
Las Vegas, NV
MKVIIS R
I searched for a list or reference myself and couldn’t find anything useful. I ended up just going to ShopDAP and buying the associated hardware kits for the transmission, as well as the suspension components. Really for me it was a lot easier that way anyways. You’d still need the pressure plate and flywheel hardware though.
https://www.shopdap.com/make-model-...ransmission-hardware-kit-for-6-speed-mqb.html
https://www.shopdap.com/make-model-...ension-install-kit-for-mk7-5g0498331bgrp.html
StorableComa
SoCal, USA
17 GSW S FWD
Shoot me your Vin and I can see if I can get you a list if needed.
-DK-
Bay Area
2017 GTI SE
Thanks fellas. I’ll check vin in morning. Appreciate the help.
DevinMK7
WA
2017 Golf GTI Sport
Looking for feedback on this list, as I am prepping for a clutch install in the next few weeks or so.
I have what I assume the full list of TTY bolts needed for the clutch install, which I kind of scavenged from the HS tuning transmission hardware kit, and the ECS Tuning basic clutch installation kit.
Currently planning on going w/ a ECS Tuning Stage 2 kit, w/ included Luk TOB, and 034 Motorsports Crankshaft Seal. Pairing it w/ an EQT Stage 2 Tune for those curious.
EDIT: I updated the spreadsheet, and it should have all the TTY bolts that will need to be replaced during the clutch install. Couple notes: I read that the transmission mount can be removed without removing the 4 bolts that go to the fender area (part #N10699701), simply remove the 3 upper, and 3 lower transmission mount bolts and leave the ones that are under the battery tray and wiring. I have all these bolts in the spreadsheet just in case if you want to remove them all, I will be since I am changing the trans mount w/ an OEM mount + BFI stage 1 insert.
-DK-
Bay Area
2017 GTI SE
What clutch are you going with?
DKM stage 2 with metal TO bearing. Already have the clutch, fluidampr and BFI mounts. Just nd hardware at this point
-DK-
Bay Area
2017 GTI SE
Currently planning on going w/ a ECS Tuning Stage 2 kit, w/ Luk TOB, and 034 Motorsports Crankshaft Seal. Pairing it w/ an EQT Stage 2 Tune for those curious.
Edit: The spreadsheet has two errors: The first row should have 3 bolts, and the second row I believe is actually for the engine mount which ECS Tuning supplies with their kit. Not sure if this is really needed tho…
This is great.
-DK-
Bay Area
2017 GTI SE
Do
HSTuning also offers a kit for clutch replacement tty hardware.
Does HS tuning have a website? All I can find is Facebook page for them. Thanks
-DK-
Bay Area
2017 GTI SE
Nm found it.
StorableComa
SoCal, USA
17 GSW S FWD
Here is what I have listed for mounting parts on your VIN. Was there any other hardware you were looking for?
StorableComa
SoCal, USA
17 GSW S FWD
You were also looking for the suspension hardware correct?
