Hello, I have just installed my new Mu21s1 ohlins set for my mk7 GTI. I like the stance (~15mm lower) but having problem with settings.
so I have played around with a couple settings from F/R: 7/7 (stiffer) to F/R: 18/18 (softer)
I found 18/18 to be quite bouncy in wavy roads . 8/8 seems better but still see some bounciness.
what do you guys recommend to set at? I am starting to think it is due to the spring rate 70n/mm, and need a stiff damping to accommodate that. but isn/t 8/8 enough?
anyways I am very satisfied with what it performs during coring and how it improves traction. just quite confused of how to reduce the bounciness while going over bumps.
What I mean by "bounciness" is like this:
The Red line is OEM: too soft but damped.
The Blue line is Ohlins at 18/18 (almost full soft): good support but seems like too much overshoot and bounciness
The Black line is Ohlins at 8/8 (winding road setting): very good support, less bounce amplitude, but frequency of bounciness is probably a bit higher (i might be wrong)
That's just the butt dyno that I had with those settings. any recommendation for the setup? Thanks in advance!
