COBB Log Comparison Thread
ashiun
Toronto, Ontario
Jedimk7
Wouldn't say it looks particularly fast, but it's clean. By the way, log relative manifold pressure for boost without having to do the whole - atmospheric pressure hubbub
That pretty much sums it up, feels quick not super fast, will let stratified figure that out once I install the intercooler, I like the no knock throughout the Rev range, will change my settings in the AP thanks for the feedback [emoji41][emoji106][emoji631]
Sent from my Gavin Belson black box signature edition
ashiun
Toronto, Ontario
Important to note that KR isn't knock per se. Under a certain amount it's just timing pull and normal corrections. Above a certain amount there's a risk for knock lol
Cameron1292
Florida
^ yep. Correction isn't bad. There's times the stock tune will pull timing just for mpg and it will show up as correction.
Sent from my ONEPLUS 5T using Tapatalk
Mels15GTI
Northwest
I don’t like the traction control on the Cobb, it works great, sometimes you just want to spin through second. I know spinning ain’t winning, it’s just about fun.
ashiun
Toronto, Ontario
Good thing you can adjust it :)
Set it at 3 or 4 and I think you'll be fine. Or set it to 9 to turn it off.
Mels15GTI
Northwest
I have it set to one right now, I don’t run around with my Accessport plugged in. When I reconnect it it goes to 1. I’m not sure if the settings are being saved. I thought 1 was all the way off?
zerocal1
Houston
Slot 1 (default) – 4000 RPM
Slot 2 – 4150 PRM
Slot 3 – 4300 RPM
Slot 4 – 4450 RPM
Slot 5 – 4600 RPM
Slot 6 – 4750 RPM
Slot 7 – Disables COBB LC Feature (Used for dyno calibration purposes)
ashiun
Toronto, Ontario
1 allows for 10% slip. 2 allows for 20% slip. 3 allows for 30% slip, etc.
If you're etuned or protuned, ask your tuner to set the default.
Slot 2 – 4150 PRM
Slot 3 – 4300 RPM
Slot 4 – 4450 RPM
Slot 5 – 4600 RPM
Slot 6 – 4750 RPM
He's talking about traction control not launch control
Mels15GTI
Northwest
Thanks, right now I’m running MA stage2. I don’t know what to consider that. I’ll mess with the adjustments and see how it goes.
marauder
Northern Va
It resets every time you restart the car. It's for that reason we adjust out 'default' to be more like a 4 instead of 1.
wordsthatiwrote
Ohio
Been awhile since ive been on the forum.
Was bored after work and my tank was pretty much bone dry.
Went to the gas station and filled up 50% 93 octane and 50% E85
I think my mods are in the signature.
Decided to put on the Cobb stage 3 93 octane tune and wanted to see what it would do.
So I did a 60 mph pull to the top of the rev range.
For what it is, it seems to have ran pretty smooth.
I uploaded my data log here: datazap.me/u/wordsthatiwrote/cobb-stage-3
Not 100% sure what it all means in conjunction with one another but i didnt see any knock retard.
Just curious of your thoughts on this. Thanks for your time.
OBP
ChiRaq
So you're running an E-48 blend on a 93 oct tune.... what could possibly go wrong?
Diggs24
de plains! de plains!
2015 GTI
Stick with 2-3 gallons.
