Not the brake pads. I had that issue and fixed it. This noise is independent of brake application.
It all started with a squeaking rubber noise while turning at low speeds. Was advised it was bad strut bearings. Decided to buy parts and tackle it myself. Also found a set of lightly used DCC shocks off a Golf R. Figured it was a good time to replace the struts as mine had about 70,000kms on them.
Took it all apart, then re-assembled with new parts, hardware, and everything hand torqued. Creaking noise gone, however it was replaced by a “thud/sproing” when turning at low speeds. Tried silicone spray in multiple spots, didn’t work. Then thought it was the spring skipping on the strut bearing…tore it apart again and put a spring silencer between the spring and bearing. Noise went away for about 2 days, thought I fixed it, elated…noise came back, despair. Just recently replaced stock sway bar endlinks with Neuspeed adjustable ones, didn’t help.
Current setup is Golf R DCC shocks, Eibach prokit springs, Neuspeed endlinks, new oem strut mousts/bearings. I had the Eibach springs installed for over 3 years with no issues/noises before all this started. My best guess now is that the shock is bad, but I can’t even bear the thought of spending thousands on new shocks and not resolving this issue. It’s really too bad, because it’s starting ruin what is an otherwise amazing car.
