fauMkVGTI
- San Antonio, TX
- Golf R
My '15 R just passed the 16k mile mark so everything should still be relatively factory fresh, the car does sit on DG springs and has been on these springs for years. About 2 weeks ago I started noticing a metallic sounding clunking noise in the front when going over certain bumps in the road. It almost sounds like someone banging against the shock tower. It seems to be most prevalent when going over bumps followed by an immediate dip (quick compression and rebound). There is no noise over speed bumps, raised bumps in the road or joints in the road.
I did replace the front pads and calipers right before I notice the clunking noise but doubled checked and all caliper bolts are torqued to spec.
Next thing I will check will be the sway bar endlings. Any ideas what it could be?
