Will_
- SF Bay Area
- 2017 GTI S DSG
I initially installed my 034 RSB with the ECS end links. The bolts were properly tightened (I thought) with the suspension loaded. Within a couple of thousand miles, the endlink connection at the RSB had become loose and regularly klunked on both sides. And I had pre-cleaned the endlink threaded studs and used blue Locktite to keep the nut tight too. I then replaced the ECS endlink with the Moog unit and it has stayed tight ever since and no klunks.
I recommend you check this connection before you go to a mechanic. You don't need a torque wrench- you can't get a socket & wrench on that bolt anyways. A crows-foot wrench- maybe. But I wouldn't trust the torque reading.
If the connection is loose, (and I'm certain it is,) tighten it as much as you can. Find out what the thread pitch is on the endlink threaded stud, then make your way down to the closest Fastenal and get a couple of jamb nuts that have the same thread as the stud. Install the jamb nuts tight to the nuts you have already installed. They won't loosen again.
Just to be sure you’re talking about the out nut here yea? I don’t see any room for play but honestly I’m not sure what else it could be so I’ll take a look.
