This is the kit I've just bought, which comes with the panel itself, trim cover, adapter cable which goes from the single plug to double plug on the back of the climate unit and 2x temperature sensors which go into the air vents, however I'm not sure where exactly they go.
My car is a GT TDi 2.0 BMT, not a base model but comes with the horribly basic manual control panel and heated seats. Just seems like a really odd mixture, especially coming from a MK4 GT TDi which had climatronic which worked absolutely perfectly.
From what I understand, when you fit this climate control unit, it will work in 'sync' mode only, rather than driver/passenger separate compartments. I'm absolutely fine with this, I just want to have a similar system to the MK4 climatronic where I can have air coming from more than 2 of the vents symultaneously, actually maintains the cabin temp and hopefully allows me to demist the front screen with the push of a button... like my 20 year old golf used to...
https://www.aliexpress.com/item/400...earchweb0_0,searchweb201602_,searchweb201603_
