If I want to get an accurate result on the dip stick, should I check it when the engine is completely cold or when it's warmed up? If I drive a little bit and wait 5 minutes to check the oil, would that give me an accurate result? I only ask because I keep getting conflicted responses. Most people say either way is fine but if that's true then why am I getting completely different results when checking while warm or cold?
